CUBASE 12
Objavljeno 03 marec 2022 - 06:56
Na voljo je nova različica Steinbergovega orodja Cubase, verzija 12.
Ta pa ponuja kopico zelo zanimivih novosti, ki pa so:
  • A new MIDI Remote system that helps to map hardware controllers to Cubase functionality;
  • The addition of a Scale Assistant to VariAudio, to aid in automatic pitch correction;
  • A new Audio To MIDI chords function, which can extract chord information from polyphonic audio;
  • A new multi-effects processor called FX Modulator, which allows you to modulate its parameters using custom LFOs, audio side-chain signals and more;
  • Improvements to the AudioWarp time-stretching algorithm, plus the ability to stretch audio directly within your project timeline;
  • Improvements to the audio editing workflow, including the addition of new keyboard shortcuts, improved navigation and new slip and nudge edit modes;
  • A new dynamics processor called Raiser, which promises extra-fast attack times and ultra-transparent limiting;
  • Sample-accurate volume automation;
  • New tools for importing tempo and signature tracks from other Cubase projects;
  • Compatibility with Bluetooth MIDI (on Windows machines);
  • The ability to export channels and stems in isolation while applying correct side-chain processing;
  • Improvements to the Logical Editor;
  • A new felt piano instrument called Verve;
  • Native support for Apple Silicon architecture;
  • Smoother waveform drawing.
Še več o novi verziji in cenah najdete na njihovi spletni strani >>>>
