Waves ponuja Studio Rack - kontejner za plugine
Objavljeno 24 julij 2014 - 07:51
StudioRack is an advanced software rack designed to save and run Waves plugin chains. It is compatible with most DAWs and allows you to save your own plugin chain presets, including the individual presets of each plugin within your chain. And no matter on which DAW you saved your presets, StudioRack will load them on any DAW.
Compatible with most DAWs
Presets for plugin chains can be saved to and loaded from any DAW
Up to 8 plugins per rack
Fully automatable
Quick access to plugin parameters within your chain
Intuitive MIDI control over all plugins
Avid Control Surface support
StudioRack Native is free for Waves plugin owners covered by the Waves Update Plan.
Več na >>>>>
#2 minimalB
Objavljeno 08 avgust 2014 - 07:28
Ce prav razumem je to zastonjsko samo za "Waves Update Plan" uporabnike?
Prispevek uredil/a: minimalB, 08 avgust 2014 - 07:29 .
