Analogni sekvencer: more-retro-than-retro :)
6 odgovorov v tej temi
#1 E.B. King
Objavljeno 11 februar 2010 - 05:56
"Christian Günther, who was in charge of electronics, and I have taken about 2 years to build the "Schaltzentrale" ('Central Switchboard') which now completes the "Heckeshorn" (Wolpert's first synth) with a sequencer as well as a few other goodies (a ring modulator, Voltage Control, and a pretty complex rhtyhm machine) and is able to control the whole thing. Sounds frigging amazing, this box! I came up with the initial idea and the casing. All parts, like the knobs and handles etc were handmade on a lathe. Same goes for the front plate, which was hand-engraved, -decorated and -etched. The back plate is adorned with a jellyfish that is coming out of an opium pipe.
I carved the encasing out of a very old pear tree burl and glued it together. The voltmeter and the bell are actually antiques (08.01.1901). There are some pics you can check out on my website."
linki: http://www.synthgear...ular-sequencer/
http://www.synthtopi...nk-synthesizer/
Prispevek uredil/a: E.B. King, 11 februar 2010 - 05:58 .
Objavljeno 11 februar 2010 - 08:44
#3 rotation
Objavljeno 06 marec 2010 - 02:17
Modeli so popizdil, kdor je kdaj vsaj kaj vgradil v ohišje mu je približno jasno koliko dela je s takšno zadevo.
Jaz občudujem Metasonix:
http://metasonix.com/
Eric Barbour, lastnik Metasonixa je pa itak junak, ima zelo inovativen pristop. Prej je delal za Svetlano, proizvajalca lamp. Generacije so se učile iz njegovih tutorialov za lampe.
Evo en intervju z njim:
http://www.synthtopi...ic_Barbour.html
Novi analogni sinti se mi v pro audiu zdijo najcenejša roba glede na vložen čas in material! Se vidi da moraš biti tudi entuziast da izdeluješ kaj takega.
Dober thread!
Prispevek uredil/a: rotation, 06 marec 2010 - 02:19 .
#4 jetam
Objavljeno 06 marec 2010 - 11:06
Res je. Če primerjaš Mooga z LA-2A-jem takoj vidiš da je nekaj precenjeno.
#5 ixi
Objavljeno 06 marec 2010 - 11:36
QUOTE (jetam @ 6. Mar 2010 11:06:48) <{POST_SNAPBACK}>
OBE ŠKATLJICI DELATA SUPER,....
#6 jetam
Objavljeno 06 marec 2010 - 11:58
QUOTE (ixi @ 6. Mar 2010 11:36:26) <{POST_SNAPBACK}>
Delata super, le da ima ena, ki je celo malenkost cenejša 100x toliko delov, to mi je malo moteče.
Po drugi strani pa če UA uspe prodajati te replike (LA-2A, 1176, 610...) po taki ceni, naj jih, meni se zdi pretirano, ker ime Teletronix ni nič bolj na nivoju od imena MOOG.
#7 rotation
Objavljeno 11 marec 2010 - 12:06
QUOTE (jetam @ 6. Mar 2010 13:58:01) <{POST_SNAPBACK}>
Pa saj je veliko drugih opcij, ena od njih je Peavey L-2. Po opisu znanca sodeč bi rekel da je zelo zelo blizu LA2A, rabljen stane okrog 1000$. To je bil Peavey-ev poizkus preboja na high-end trg, a zgleda da ime ni primerno:
http://www.harmony-c...vey/VC-L-2.html
Zadnjič sem na eBay-u našel kopijo RCA BA-2A, zgleda zelo dobro narejena, zraven je bil tudi filmček ki je dobro pokazal notranjost. Zdaj ga prodajajo tu:
http://www.vintagelo...ogdualevel.html
Malo manj kot 4000$ s poštnino za takšen izdelek je zelo malo. Ali ne stane samo en kanal UA LA2A 3000$?
Občasno na eBay-u opazim tudi dobre kopije SSL4000 za okrog 800 evrov, po forumih se pa dobi še za manj če malo poiščeš. Pa ne govorim o Gyraf verziji, to so prave kopije, večinoma je tudi ohišje lepo narejeno...
Zadnjič je nekdo prodajal dva kanala Neve 1290 (1073 brez eq) za 700 evrov, ful lepo narejeno z original transformatorji.
Odkar so vse sheme (brez napak) dosegljive na netu res nima smisla izgubljat besed o UA. Kdor ima denar kupi original, kdor pa ne, a ima znanje in ve kaj išče pač malo pobrska za cenejšimi opcijami. Toliko kot danes jih še ni bilo, pa kaže da jih bo še več.
Prispevek uredil/a: rotation, 11 marec 2010 - 12:14 .
