Lexicon plug-in reverb PCM Native Reverb Plug-in Bundle
36 odgovorov v tej temi
#1 satoration
Objavljeno 10 oktober 2009 - 12:25
No, končno.
Najbrž bo to tudi konec ITB-OTB debat, vsaj kar se digitalnih reverbov tiče...
"Finally, hardware quality without the hardware
For over 35 years Lexicon has been recognized as the golden standard of digital reverb and effects processing and has continuously introduced leading edge technology for the audio industry. Lexicon has again rocked the audio industry with a complete collection of the finest reverb plug-ins available. The PCM Native Reverb Plug-In Bundle is the ultimate reverb plug-in for creating professional, inspirational mixes within popular DAWs like Pro Tools, Logic, and any other VST, Audio Unit, or RTAS compatible platform.
With all the flexibility you would expect from a native plug-in, this powerhouse Bundle delivers 7 legendary Lexicon reverbs with hundreds of the most versatile and finely-crafted studio presets, including recognizable classics from Lexicon’s immense library of sounds. Designed to bring the highest level of sonic quality and function to all your audio applications, the PCM Native Reverb Bundle will take center stage in your DAW.
Features at a Glance
PCM Reverb Plug-In 7 Algorithms
* 7 legendary Lexicon Reverbs: Vintage Plate, Plate, Hall, Room, Random Hall, Concert Hall, Chamber.
* Hundreds of brilliantly crafted studio presets
* Multi-platform compatibility (Windows XP, Vista, and 7; Mac OSX 10.4, 10.5, 10.6, PowerPC and Intel)
* Formats that work seamlessly in any VST, Audio Unit, or RTAS compatible DAW
* Graphical real-time display illustrating the frequency stages of each algorithm
* Visual EQ section for easy adjustment of both early and late reflections
* Presets can be stored in a DAW independent format which allows custom presets to be transferred between any DAWs.
* Full parameter control and automation
* Input and output meters for quick assessment of audio levels going to and from the reverb
* iLok authorized"
Cena: $1,899
Formati: VST / Audio Unit / RTAS
http://www.lexiconpr...duct.php?id=163
#2 Katoda
Objavljeno 10 oktober 2009 - 01:18
kere cene si te firme nudijo. drugače pa ja, komaj čakam, da ga primerjam z Altiverbom
#3 satoration
Objavljeno 10 oktober 2009 - 01:35
Ma, veš, če je res enake kvalitete kot vrhunske Lexicon "škatle", potem je še poceni, a ne. Pa fleksibilnost plug-ina. Super!!! Pa to ni končna cena, v prodaji je ponavadi precej nižja...
Sicer pa odkar imam Bricasti in TC6000 impulze naložene v Virsyn Reflect ne pogrešam kaj dosti...
Objavljeno 10 oktober 2009 - 02:27
hehe na GS se že kregajo da SW/ native ne zveni isto in tako dobro kot HW pa čeprav jim sam programer razlaga, da je celo odpravil neke buge iz HW PCM96 sofwearea... neverending story... še malo bodo začeli z blind testi...
Enkrat je Bruce Swedien dobro rekel, da se spomni ko so prišle prve reverb mašince, da so se enako kregali, da ti reverbi niso dobri v primerjavi s pravimi emt plate ali dobrim primernim prostorom...
Objavljeno 10 oktober 2009 - 05:29
About differences in the sound between PCM96 and Plugs - Klik
I've seen speculation about there still being differences in sound. One of the commenters with demo code has stated there is a difference. Time for a bit of explanation.
One of the bugs I fixed had to do with a parameter called "Tap Slope". It's busted in the PCM96 (as strongly attested by zmix) and it's fixed in the plug. It does cause a small difference in sound, and I will fix it in the 96 when I've got time.
There were a number of small changes I made in the way reverb decay time is measured. This means that there will be tiny differences in the time between the plug and the box--especially at small room sizes. One thing I've learned is that mixers use their ears anyway and not the numbers. It's easy to tweak from the fader, which is why it's always in the soft row. I'll backfill those changes in the box too, when I've got a chance.
There are a number of other little tweaks, noticeable or not, that are in my notes. So I'm not slavish about duplicating old stuff--warts and all. They are still the same algorithms--with corrections. They are in no way crippled.
And finally, I've been spending time 'recalibrating' presets. In general, you want something like unity gain through a preset. In truth, you can't get there, since the response of a reverb is so strongly dependent on the source material. But I'm still tweaking gains.
So even if you turn off spin, you'll find that algorithms don't null. Should they?
I've just begun a week of badly-needed vacation. I'll monitor this list while I can, but responses will be infrequent. I'm not ignoring you for good--just for a while.
N.S.
#6 Katoda
Objavljeno 10 oktober 2009 - 07:24
še vseeno se mi zdi, da je tukaj ena prepreka , ki onemogoča Lexi SW zveneti kot Lexi HW. dejanski HW, ki ga uporablja HW hahaha, kolko čipov potrebuje PCM96 da shendla svoje algoritme ?
brikasti jih ma kolko ? ducat dobrih dual core procesorjev
PS: šest dual core procesorjev ja - http://www.bricasti.com/m7.html
Prispevek uredil/a: Katoda, 10 oktober 2009 - 07:48 .
Objavljeno 10 oktober 2009 - 09:15
Njihov programer (ta tip kamor vodi link do njegovega posta) ali kakšen naziv ima pravi da ni neke frke glede tega in da nič ne trpi, algoritmi niso okrajšani, poenostavljeni ipd. le popravljeni, saj naj bi HW enota oz SW naložen nanj imel napake, katere bo pa tudi na HWju popravil (ko bo imel čas).
tukaj pri bricastiju vidim pod "Tech Specs" da ima "6 state of the art dual core DSP"-je od analog devices-a.
To niti približno ni enako kakor Intelovi CPUji ali AMDjevi mlinčki... nVidia ali Ati GPU grafični procesorji.
Ti so mnoooooogo bolj sposobni kakor bilo kateri DSP!!! tudi dual core!!!
DSPji so prepočasni glede na sodobne procesorje, lahko se poglobiš in primerjaš specifikacije mlinčkov.
... imaš še FPGA tehnologijo ki ga recimo uporabljajo pri Fairlight Crystal Core tehnologiji (je pa FPGA zelo občutljiva na buge v programu in zelo zanesljiva, če jih ni...)...
CPUji so celo bolj od zadaj kakor GPUji (Tesla/ Cuda nVidiin princip recimo)... ampak to je že druga zgodba...
#8 Katoda
Objavljeno 10 oktober 2009 - 11:30
razumem da so DSPji v določenem pogledu drobtinice kar današnji CPUji nudijo ampak casey (bricati developer) med drugim trdi:
Running a single Bricasti algorithm on your example computer would be about the same as running three thousand 720X480 mpeg videos all at the same time, just in terms of the memory bandwidth required.
And this does not even factor in the wild memory access patterns that the Bricasti reverb algorithm requires.
When this is taken into account, it turns out that the memory bandwidth requirement is only half the problem. The access patterns just destroy the shared memory and cache resources of any standard computing platform, and represent the more difficult issue to overcome.
The Bricasti M7 algorithms cannot be run on todays commercial platforms. Better wait 5 years. Even then I doubt it.
The M7 has greater than 20x the performance of any other 1U reverb.
The M7 has 12x the performance of an entire TC 6000.
The M7 has the equivalent processing power of 5 Digidesign Accel CARDS.
If you want the best reverb you need to supply the horsepower. It is a simple fact. Reverb hardware is simply superior at running the best algorithms than the best Intel based platforms.
sicer sem pa prepričan da bo kr rastrgal gate tudi plugin
#9 Blaster
Objavljeno 11 oktober 2009 - 04:04
Če koga zanima ... Lexicon 960L je navaden PC s Pentium 233MMX, 32Mb RAM-a in enim majhnim hard diskom, CD-ROM-om, disketnikom ter veliiiiikkkooooo DSP plato, na kateri vse utripa, lol ... Poleg vsega navedenega ima še eno grafični kartici podobno karto, ki omogoča prikaz na LARC-u in kontrolo preko LARC-a. Seveda ne laufa na XPjih ali čim podobnim, ampak na Lexiconovem OS-u.
To je vse... Osnova pa je PC.
Software, ki krmili vso zadevo ter algoritmi, pa so seveda pisani za njihove DSP-je.
Objavljeno 11 oktober 2009 - 08:25
QUOTE (Katoda @ 11. Oct 2009 00:30:28) <{POST_SNAPBACK}>
On tudi primerja jabke in hruške... dsp platforme in nato intel platformo (ne vem kakšno ima v mislih:)).
TC ima počasne dsp motorole, digidesign je tudi zelooo out of date, najnovejši dsp-ji od analog devices so mnogo boljši a zelo daleč od CPU in GPUjev (tudi UAD ima zelo frišne analog devicesove dsp-je).
Je pa res, da je potrebno CPU platformo optimizirat da ne dela preveč drugega kakor gnati algoritme tako kot recimo Mergingova Mass Core tehnologija, ki med drugim tudi določi kaj bo katero CPU jedro počelo...
Kot je Blaster rekel Lexicon 960L je prirejen PC, PCM96 je novejši sistem ampak tudi prirejen PC, Bricasti izgleda da ima pač še močnejši sistem, mi pa imamo skoraj vsi dvojedrne, štiri in večjedrne rač.
Kompjuterske moči kolikor hočeš razen, če se nočeš znebiti HW dongla, ki te ščiti pred cracki (iLok ipd. zaščite se dajo z nekaj truda uspešno hacknit).
#11 minimalB
Objavljeno 11 oktober 2009 - 09:51
Wow,
Zame je to kar lep dokaz, da se prihodnost seli v racunalnik in da so to tudi najvecje firme pocasi primorane sprejeti.
Kar se mene tice - naravnost SUPER.
#12 Blaster
Objavljeno 11 oktober 2009 - 01:07
Me pa zanima, kako se bo obnesel ... Zaenkrat še karkoli sem probal, naj bo software, naj bo hardware ... ga ni TC-ja, Bricastija, itd ... ki bi se lahko primerjal z Lexiconom 960L.
Sicer stvar okusa, ampak ... mašina RES dela.
#13 Katoda
Objavljeno 11 oktober 2009 - 05:32
kaj pa kej razvijalci pri lexiconu pravijo glede čipovja ki jih njihove mašine koristije in HW zahtev za poganjanje tega plugina ?
#14 Johnny
Johnny
  • 76 prispevkov
Objavljeno 11 oktober 2009 - 05:57
Tud jaz bi probu razliko med Lexiconovem impulzom v Altiverbu s tem novim pluginom. Blaster ti imaš sigurno primerjavo med 960L impulsom v Altiverbu in pa s HW škatlo. Me zanima če si delal primerjavo, da mal pokomentiraš.
#15 NLP
Objavljeno 11 oktober 2009 - 06:38
QUOTE (Katoda @ 11. Oct 2009 18:32:19) <{POST_SNAPBACK}>
kot je rekel prej Blaster:
"Če koga zanima ... Lexicon 960L je navaden PC s Pentium 233MMX, 32Mb RAM-a in enim majhnim hard diskom, CD-ROM-om, disketnikom ter veliiiiikkkooooo DSP plato, na kateri vse utripa, lol ... Poleg vsega navedenega ima še eno grafični kartici podobno karto, ki omogoča prikaz na LARC-u in kontrolo preko LARC-a. Seveda ne laufa na XPjih ali čim podobnim, ampak na Lexiconovem OS-u.
Software, ki krmili vso zadevo ter algoritmi, pa so seveda pisani za njihove DSP-je."
PCM96 je pač novejši sistem.
Pravijo, da ni frke zato so se odločili izdati native verzijo.
Sicer pa bo kmalu dosegljiv tudi uraden demo pa se bomo lahko prepričali (enim so talali demo že na AES-u v New Yorku).
#16 Blaster
Objavljeno 11 oktober 2009 - 08:42
QUOTE (Johnny @ 11. Oct 2009 18:57:23) <{POST_SNAPBACK}>
Lahko ti jo naredim, ni panike. Pošlji mi impulz in podatke, kaj naj bi ta impulz "predstavljal" (algoritem, nastavitve...) da 960ko nastavim isto in ti lahko pošljem obe varianti.
#17 Vsestransky
Vsestransky
  • 96 prispevkov
Objavljeno 12 oktober 2009 - 02:10
QUOTE (NLP @ 10. Oct 2009 15:27:51) <{POST_SNAPBACK}>
Kar je sevede res. pravi plate-i in naravni prostori so neprimerno boljši. kaj čmo zadeve so definitivno zmer slabše. edina razlika je, da dons lahko že vsak snema..
#18 Katoda
Objavljeno 20 januar 2010 - 08:01
neki se šušlja da je lexiconov bundle že ....khm khm "na voljo" whistling.gif bojda samo za PC zaenkrat
#19 Blaster
Objavljeno 20 januar 2010 - 08:57
Res je ...
Če koga zanima, lahko enkrat nardim test...
#20 jetam
Objavljeno 20 januar 2010 - 09:38
Seveda nas zanima.
#21 ixi
Objavljeno 20 januar 2010 - 11:34
QUOTE (Katoda @ 20. Jan 2010 20:01:00) <{POST_SNAPBACK}>
#22 Psyko
Objavljeno 21 januar 2010 - 03:17
#23 satoration
Objavljeno 21 januar 2010 - 02:05
QUOTE (Blaster @ 20. Jan 2010 21:57:50) <{POST_SNAPBACK}>
Res je ...
Torej, a zdrži primerjavo z 960L ali ne?
Sicer bi skoraj lahko verjeli avtorju produkta, da je ta plug-in enako dober kot njihove top škatle, pa vseeno... test ne škodi... Kakšen je tvoj vtis, pa če lahko pripopaš kak primer z enakim algoritmom iz plug-ina in 960ke, bi bilo super.
#24 Blaster
Objavljeno 22 januar 2010 - 02:59
Lexicon PCM Plug-In
Lexicon PCM91
Lexicon 960L
#25 satoration
Objavljeno 22 januar 2010 - 04:12
Zanimivo, zveni, kot da je na PCM native primeru več reverba, kot na ostalih dveh. Mogoče daš malo manj, da bo enako? Plug-in in 960L sta si precej podobna po "transparenci", a mi škatla zveni malo "topleje", a mogoče samo zato, ker je nekaj manj reverba? 91ka pa je malo bolj "mutna", a tudi zanimiva.
#26 NLP
Objavljeno 22 januar 2010 - 07:08
Programer pri Lexiconu je na GS komentiral, da bi morala razlika biti le zaradi konverterjev v Lexicon kišti dunno.gif
#27 Blaster
Objavljeno 22 januar 2010 - 11:09
QUOTE (NLP @ 22. Jan 2010 19:08:37) <{POST_SNAPBACK}>
Kakšnih pa, če pr men vse laufa na AES/EBU ?
#28 NLP
Objavljeno 22 januar 2010 - 11:29
Ja sem mislil, da boš rekel to, ker so omenjali to tudi drugi:)
To je bil odgovor od programerja.
Je pa res tudi da je rekel da je popravil nekaj bugov ki so bili prisotni pri SW-ju v HW kišti in je SW posodobljen v vtičniku... mogoče to?... ter da bo enkrat ko bo imel čas dal updejt tudi za HW kišto.
V bistvu pravi da razlike ne bi smelo bit ker ni logično, razen morda zaradi psihe oz. tistega ki primerja ...
http://www.planetaud...st=0#entry27591
glej moje poste še iz tega threada:
- http://www.planetaud...amp;#entry25782
- http://www.planetaud...amp;#entry25785
#29 BlackOrWhite
Objavljeno 23 januar 2010 - 12:18
Na "izzvenih" se sliši razlika. 960L je nekako najbolj "naraven".
Ampak se da napimpat tud plugin dost podobno očitno, saj so to ble čimbolj podobne nastavitve (po vrednostih, ne po dejansko slišanem). Pa tud določene nastavitve se ne da isto nastavit, ker majo različno skalo.
Ne vem kaj so mislili pri Lexiconu sicer....ampak...jaz ne kupim nobenga hardwarea od njih, dokler bojo plugi tako dobri. Glede na to da so pa še to skrekal...sej bojo propadli smile.gif
saj so najbrž vedeli v kaj se spuščajo, tako da zihr majo neko računico. Saj jst zaenkrat še ne vem v čem je fora, da so sploh tako dober plugin izdali, in si nardil tako konkurenco hardwareu. Sej so vedli, da jih rusi komaj čakajo.
#30 ixi
Objavljeno 23 januar 2010 - 09:24
Meni zveni PCM nateve fenomenalno zelo podobno kot HW, strinjam se z saturation-on in tabo BlackOrWhite-om, je razlika v izvenu, kot da bi bil HW daljši,... ampak smo se pogovarjali da nas zanima razlika pri istih nastavitvah = ja tako ??
Je pa sigurno res da se ga da napimpat isto SW kot HW ! (OT: isto je pri Fatso-tu HW & SW, iste nastavitve , zelo podoben sound, če pa daš enga v proti fazo ga napimpaš natanko isto kot HW, tako je z vsako high-end stvajo, ki je emulirana na ta način.
Sem pa še davno opazil, da je zarlika pri reverbih ta, za moj okus zvenjo HW-ski reverbi dosti boljše če imajo v škatlji-ohišju vgrajen napajalnik, kot pa da so na adapter !! Ne vem zakaj, mogoče samo psiha smile.gif)
