Novaflash Geektronic Stereo Bit Crusher free VST plugin
Objavljeno 24 september 2009 - 03:32
Novaflash Geektronic vam ponuja povsem zastonj stereo bit-crusher/decimator efekt.
Kaj pravijo:
simple and efficient, a nice alternative to complex and bloated audio effects.
Geektronic options include:
* PRST : Sample Rate standard presets. When set to FREE use the SR knob.
* SR : Allow any frequencies between 500 Hz to 20Khz.
* BITS : Reshape the audio stream ( 2 to 24 BITS)
* BEND : Smooth an re-shape the front side.
* BENDSHP : Three mode post shaping. Smooth UP and DOWN front side, only UP, only DOWN. updown
* EQ : Post EQ. Positive value boost the selected frequency. Negative value attenuate it.
* MIX : 100% full effect. 0% by-pass the effect.
* GAIN : -6dB to +12dB
Več info in za snet na: novaflash/vst/geektronic
