Krekanje - (Uad - Software je skrekan)
34 odgovorov v tej temi
Objavljeno 09 oktober 2006 - 07:44
Čisto me je šokiralo ko sem na netu najdel "Universal.Audio.UAD-1.VST.Unlocked.v4.4.0-AiR"!
Tele krekrski teami so čist divji !!!!
Kaj vi menite o krekanju, je v redu ali je to salabo
#2 Matox
Matox
  • 74 prispevkov
Objavljeno 09 oktober 2006 - 07:56
V smislu "try before you buy" je zadeva odlična. Itak nihče v registriranem studiu ne bo uporabljal in navajal plugov, ki so piratski... Inšpekcije so zajebane in lahko ostaneš brez biznisa oz. s konkretno kaznijo. Dokler pa nimam uradno studia odprtega, pa se redno poslužujem takšnih metod...
Vse je relativno!
#3 Katoda
Objavljeno 09 oktober 2006 - 01:13
kje si pa to našel če ni skrivnost?
drugače pa nekaj malega na to temo
What's worse, I suspect it is a trojan.
Both
Nomad.Factory.BlueVerb.DRV-2080.VST.RTAS.v1.1-AiR
Eliosound.AirEQ.VST.RTAS.v1.1-AiR
are trojans, I believe.
See the stupid fake "AiR.nfo" files in them?
Then, about the "setup.exe" files:
The little AiR icon is easy to copy in, just 744 bytes.
This is the code for that icon.
All H2O releases, and all AiR releases with own installers (i.e. not serial / keygen releases, but those with cracked .dll's)
have always been made with the installer creator programs from Wise.
http://www.wise.com/...tallations.aspx
The installer files in these fake AiR releases are not made with Wise.
What's worse, they contain these strings:
"Cannot load 'Launcher' function in"
"%sgert%i.dll"
"Cannot create"
"The installer file is corrupted. It was downloaded with errors or otherwise damaged."
"Please download it again and make sure that you do not have viruses."
If you search on Google for these strings, you will get many references to a
fake Windows update with a keylogger trojan, the "Windows-KB899588-x86-ENU-exe"
http://www.google.co.....-x86-ENU-exe"
So.. these files are so new, made 2006.09.21, that virus-scanners will maybe not spot them yet.
You may try to upload them to your virus-vendor, and tell them you wonder if it's a trojan.
I am not sure what installer creator program that uses those
"C:Documents and Settings(user name)Local SettingsTempgert(some number).dll" files.
Does anyone know?
Btw, the real retail installer programs (maybe some are demo versions?) are also in there.
At least parts of them - I don't have the retail ones, so I can not compare.
#4 satoration
Objavljeno 09 oktober 2006 - 02:03
Brez piratstva ne bi bilo polovice ali celo več uporabnikov izmed katerih postane kar nekaj bodocih hvaleznih strank... Tako da cisto "bad" to ni - pa tisti, ki ta software kradejo, ga tudi sicer ne bi kupili ali pa bi pac uporabljali "light" verzije, tako da ne moremo govorit da so firme zaradi tega na zgubi. Resni uporabniki pa itak slejkoprej kupijo licencno verzijo.
Pa dobre so bile poteze - ne spomnim se katere firme - ki je ponudila ugodno varianto "legalizacije" piratske verzije.
Sicer pa je podobno kot pri CDjih... Precej softwarea je enostavno predragega - npr. Wavesovi paketi - kdo bo to kupoval dandanes... Za ceno diamond bundla dobis UAD-1 ultra pak + se tri dodatne PCI kartice (project pak) + vse dodatne plug-ine, ki se niso v ultra paku. Pa primerjajte kvaliteto in fleksibilnost, ki jo imas z enim ali drugim...
Na razprodajah pa si marsikdo kupi CD za 1000 sit, a ne. Ce bi to bila izhodiscna cena bi tudi piratstva bilo manj. Diamond bundle za 100 jurjev bi verjetno marsikdo kupil, za pol milijona ali celo nekaj vec, pa ziher ne...
"Try before you buy". Oz. "buy when you earn enough" !
UAD je najbrz fake...? Pa njihovega softwara ne bi bilo fair krast... Cene dodatnih plug-inov so vec kot fair za to kaj ponujajo...
#5 ixi
Objavljeno 09 oktober 2006 - 02:35
QUOTE (Katoda)
Samo zadeva bi deloval če bi imel driverje od v.4.4.0 !
Ni nobenih horsov, bi jih pravočasno :smt117
#6 Blaster
Objavljeno 09 oktober 2006 - 09:59
ixi, upam da si res preveru, ker drgač sm že okužen po dolgem in počez... :oops:
#7 Blaster
Objavljeno 09 oktober 2006 - 11:59
Skratka, če ima mogoče kdo UAD-1 software oz. driver verzije 4.4.0, se toplo priporočam, ker so ga umaknili iz uradne strani.
Mogoče stvar celo prepričam, da dela. :oops:
#8 Katoda
Objavljeno 10 oktober 2006 - 10:09
nekaj ne razumem...tale krek verzija deluje brez kartice?
#9 minimalB
Objavljeno 10 oktober 2006 - 10:15
Ce ta krek slucajno deluje sem preprican, da potrebujes kartico. Gre zgolj zato da so plugini precej dragi (se hitro nabere veliko denarja, ko sestejes koliko das za vse dodatno kupljene plugine) in ti jih v tem primeru verjetno ni treba kupit...
Kakor jaz vem je to en navaden virus...
Drugace pa imam jaz 4.0 software nekje na disku v studiu.
Objavljeno 10 oktober 2006 - 10:20
Ne more delovat brez kartice, saj je software napisan izrecno za ua "grafično" kartico in aplikacijo "razume" samo ona.
#11 ixi
Objavljeno 10 oktober 2006 - 10:23
QUOTE (Katoda)
Ne deluje brez kartice, temveč so vsi plugin odklenjeni !
Potrebujemo le driverje za v.4.4.0!
Sem pa opazil da so vse verzije na www.uaudio.com razen v.4.4.0 ni nikjer, torej zadeva deluje in se je UA zaščitil na tak način da jo je enostavno odstarnil! No to je moje razmišljanje!!!!
Z instaliranjem prideš dao točke kjer ti sporoči da niso tapravi driverji!
#12 Blaster
Objavljeno 10 oktober 2006 - 01:58
Folk, nehite me strašit, da je to virus, k men NOD32 nč ne najde, Ad-Aware tud ne, ...
Razen če je res kej neprepoznavnega. Pol sem se pa zaj...
Skratka, zrihtajte mi original UAD-1 4.4.0 verzijo, pa bo vse jasno. laugh.gif
#13 ixi
Objavljeno 10 oktober 2006 - 02:28
QUOTE (Katoda)
P.s. Ne paničarite z trojanci ker tudi tale dva plugina delat in nista nikakeršni virus :!:
#14 greenhorn
greenhorn
  • 231 prispevkov
Objavljeno 11 oktober 2006 - 10:01
Kako pa druge države gledajo na piratstvo; npr: Anglija , Nemčija, baje je tam tega manj?
#15 ixi
Objavljeno 11 oktober 2006 - 10:21
QUOTE (greenhorn)
Verjetno drži, deln otudi zaradi višjega življenskega standarda, poštimanih finančnih stvari glede avtorskih honorarjev in pravic :smt022
Potem je v začaranem krogu produkcije več denarja, muzičar plača studiu produkcijo ta lahko vlaga v opremo ipd. tongue.gif
Glede življenskega standarda pa isto več denarja več muzike, plugin stane pa isto za nas kot za njih samo za naše razmere je npr. 300€ veliko za njih pa manj!
Glede tega se strinja za Teamom H2O "try before buy" samo mi vsi samo probavamo skos :twisted:
#16 Blaster
Objavljeno 11 oktober 2006 - 11:12
ixi, te morm popravt, v tujini ne plača muzičar studiu, ampak založba.
#17 NLP
Objavljeno 12 oktober 2006 - 10:57
Glede tega se strinja za Teamom H2O "try before buy" samo mi vsi samo probavamo skos :twisted: - ixi
Hah, ta je odlična!
#18 Blaster
Objavljeno 12 oktober 2006 - 12:12
Sporočam vam, da je AiR crack za UADa fake... upam, da se nism česa nalezu z njim, ampak... NE DELA! Oz. dela tko, k da maš originalni software gor.
#19 satoration
Objavljeno 12 oktober 2006 - 01:50
No kul, da lahko se zmeraj recem, da sta Neve Eq in compr plug-ina najboljse porabljenih 90k doslej...
#20 greenhorn
greenhorn
  • 231 prispevkov
Objavljeno 12 oktober 2006 - 02:19
Je kdo že sprobal preden je kupil smile.gif Ableton Live v6 0 1-AiR?
Dela?
#21 Katoda
Objavljeno 13 oktober 2006 - 04:08
malce faljen topic se mi zdi ampak vseeno...6.0.1 dela čist fajn,mal je izbolšan zoom pa to...pa še en kup stvari
#22 kosta77
kosta77
  • 278 prispevkov
Objavljeno 15 oktober 2006 - 04:15
Se prav, da ne dela AiR verzija?
eh, no...
Men pa 5.2.2 (original) fajn dela pa po 6 beti ne čutim neke potrebe po apgrejdu (sploh pa ne sampler pa instruments...)
k77
(zdravo iXi)
#23 Katoda
Objavljeno 15 oktober 2006 - 08:01
AiR verzija dela čist fino fajn
#24 kosta77
kosta77
  • 278 prispevkov
Objavljeno 15 oktober 2006 - 08:25
QUOTE (Katoda)
hmm, a se instalira namest original 4.4 gonilnikov? se pravi one dol, pa te gor? in so vsi plugini na voljo?
no, pol pa ze moram probat.
hvala
k77
#25 greenhorn
greenhorn
  • 231 prispevkov
Objavljeno 15 oktober 2006 - 08:29
URS Everything EQ Bundle.
A to zadevo kdo pozna?
#26 Katoda
Objavljeno 15 oktober 2006 - 09:14
@kosta: i was talkin' about Ableton 6.0.1 verziji
@greenhorn: very very good bundle
#27 kosta77
kosta77
  • 278 prispevkov
Objavljeno 15 oktober 2006 - 09:49
QUOTE (Katoda)
ja sej sej, sm hotu sam pripomnit da se mi 6ka ne zdi tolikšna revolucija da bi apgrejdov, al pa crack zdownloadov, a je kej tazga kar bi res rabu tam not (kaj je tolk bolš od 5ke, razen video import pa par pluginov)?
#28 Katoda
Objavljeno 16 oktober 2006 - 12:36
no načeloma ni nič kaj takega nepogrešljivega kar ne bi mogel dobiti iz 5ke. ima pa lep Folder management
#29 satoration
Objavljeno 16 oktober 2006 - 08:36
QUOTE (greenhorn)
Ce nimas UAD kartice in plug-inov pa se kaksnih Waves SSL, potem dela zelo v redu... Sicer pa nima sans!
Gre za simulacije klasicnih EQjev (kak drug URS bundle pa se kompresorjev) - lahko lepo pozivi tvoje mikse...
Sploh URSova klona SSL in Api EQja sta kar uporabna...
#30 ixi
Objavljeno 16 oktober 2006 - 09:14
QUOTE (greenhorn)
Meni osebno URS-i delojo zelo dobro tako compressor-ji kot tudi Eq-ji!
@satoration: si pa res čisto napalil :smt074 za Neve na UAD-u
