ADAM AUDIO nova SX serija
29 odgovorov v tej temi
Objavljeno 29 marec 2009 - 03:08
Ste pogrešali močnejše magnete, daljšo pot premikanja membrane, novejše materijale, boljše ampe, manjšo distorzijo...
Evo nova SX serija priljubljenih adam-audio zvočnikov.
Press release:
"ADAM Audio presents new SX-Series
The German specialist for professional monitors will showcase completely new top series: world premiere at Prolight & Sound
Berlin/Frankfurt, April 2009
Just in time for their 10th anniversary, ADAM Professional Audio announces a new top-line of studio monitors. The new SX-Series is based on the highly acclaimed S-Series. However, it is not a simple revision of existing models but a fundamental transformation with no details having been overlooked and every sound crucial aspect has been evaluated. All transducers, drivers and electronics have been redesigned. The result is much more than an improvement; it is a quantum leap in professional monitoring.
All 6 models (S1X, S2X, S3X-H, S3X-V, S4X-H, S4X-V) feature the new X-ART (eXtended frequency response) tweeter. It’s fundamental principle of accelerating air is the very same as the proprietary Accelerating Ribbon Technology but with a 4dB higher efficiency, a 3dB higher maximum sound pressure level, and an increase in frequency response up to 50 kHz.
Also, ADAM designed a completely new broadband amplifier to perfectly match the X-ART tweeter. The A/B amp shows ultra low distortion figures together with an excellent damping factor. An internal bandwidth of more than 1 MHz is externally limited so that the unit delivers an ultra wide response up to 300 kHz. With nothing limiting the talents of the X-ART tweeter, the monitor has unsurpassed clarity and openness, which will please, amaze and thrill even the most experienced professional ear.
The HexaCone™-woofer used exclusively is ADAM monitors have also been redesigned with larger and longer voice coils that deliver more linear excursion for higher SPL max. values. A stronger magnetic structure is added as well for an optimum in efficiency and accuracy.
Last but not least, ADAM has developed a new, innovative front panel with sophisticated controls. These controls allow the user to adapt the speakers to the sound room with high precision. The panel can be found on the models S2X, S3X-H and S3X-V as well as S4X-H and S4X-V.
The models of the brand new SX-Series will be showcased at Prolight & Sound 2009 for the first time."
Poročajte, ko jih boste primerjali s starimi...
Več info na: adam-audio.de
Cene: Klik
#2 microsound
Objavljeno 29 marec 2009 - 03:33
...u sexy....skor porno ...sm zadovljen uporabnik A7 ....mmmm to treba slišat
  • 3.882 prispevkov
Objavljeno 29 marec 2009 - 03:51
Mater si me prehitel, jst pa glih pišm članek o tem
So kr dobr nardili tele Adami, upam da se jih bo dalo slišat kej v frankfurtu.
Objavljeno 29 marec 2009 - 04:18
Jawohl!
četudi sem pod anastezijo v bolnici, opravljam svoje administratorske dolžnosti fuhrer IXI!
... ja lepo izgledajo.
#5 BlackOrWhite
Objavljeno 29 marec 2009 - 04:28
QUOTE (ixi @ 29. Mar 2009 15:51:08) <{POST_SNAPBACK}>
#6 Blaster
Objavljeno 29 marec 2009 - 06:24
Men so grdi za popeesdt.
Sorry.
LP,
T
#7 kochobass
Objavljeno 29 marec 2009 - 08:01
#8 Blaster
Objavljeno 29 marec 2009 - 08:03
QUOTE (kochobass @ 29. Mar 2009 20:01:51) <{POST_SNAPBACK}>
Aja, saj res... izgled ni pomemben, važno je srce. LOL
#9 microsound
Objavljeno 29 marec 2009 - 08:22
QUOTE (Blaster @ 29. Mar 2009 18:24:18) <{POST_SNAPBACK}>
Sorry.
LP,
T
men pa lepi ....o okusih se ne debatira
#10 BlackOrWhite
Objavljeno 29 marec 2009 - 08:55
ah daj daj blaster, kaj jim pa manjka smile.gif men prou v redu zgledajo smile.gif odvisno od ledice ki/če zasveti ko ga užgeš smile.gif smile.gif
#11 Blaster
Objavljeno 29 marec 2009 - 09:06
Tud S3A niso ne vem kako lepi, ampak vseeno lepši od teh, ki zgledajo prav poceni kitajsko, tud če so narjeni v nemčiji.
#12 BlackOrWhite
Objavljeno 29 marec 2009 - 09:27
#13 boti
boti
  • 5 prispevkov
Objavljeno 29 marec 2009 - 09:34
Dobr je vse kar je grdo
#14 Blaster
Objavljeno 29 marec 2009 - 09:39
QUOTE (BlackOrWhite @ 29. Mar 2009 21:27:46) <{POST_SNAPBACK}>
Valda, če jih ni še noben slišal. O čem pa naj bi se pogovarjali?
#15 muzikant
Objavljeno 29 marec 2009 - 09:49
Sigurno obstaja psihološka povezava... če ti vizualno niso všeč, ne morejo zveneti dobro strongbench.gif jumping0046.gif
Mimogrede so tudi meni bolj kot ene kante poster_oops.gif , čeprav najbrž špilajo super.
#16 BlackOrWhite
Objavljeno 29 marec 2009 - 10:11
QUOTE (Blaster @ 29. Mar 2009 21:39:30) <{POST_SNAPBACK}>
zato pa pravm da ni o soundu ne duha ne sluha
pa tud še lep cajt jih noben ne bo dokler jih v audiopro ne dobijo smile.gif
IXI?
#17 ixi
  • 3.882 prispevkov
Objavljeno 30 marec 2009 - 07:26
QUOTE (BlackOrWhite @ 29. Mar 2009 16:28:48) <{POST_SNAPBACK}>
QUOTE (BlackOrWhite @ 29. Mar 2009 22:11:32) <{POST_SNAPBACK}>
IXI?
#18 Blaster
Objavljeno 30 marec 2009 - 11:13
Ah, S3A pa res niso naporni. Predvsem je vse odvisno od placa. Recmo pri meni delajo čisto drugače, kot pri npr. KARIZMI. Saj je z vsakimi speakerji isto.
S3A je zelo dober speaker, tudi če si berete gearslutz ga vsi bolj ali manj hvalijo. Samo, da ne bodo naredili take napake kot Yamaha, ki je nehala delat NS-10 ter dala ven HS serijo, ki nima veze z NS-10.
LP,
T
#19 ixi
  • 3.882 prispevkov
Objavljeno 06 april 2009 - 07:45
Jaooo.
S3X smo poslušali na sejmu, je totalna razlika proti S3A. Manj moteči- ne nasikani, ne naporni, srednji in nizki so full lepo poštelani. - to govorim za horizontalne.
S3X V vertikalni so pa za moj okus še boljši. nevem kako naj to opišem vendar je sound za moje pojme fenomenalen.
S2X - je pa za moje pojme čist podrt zvočno - ga A7 poje - dobesedno
#20 Blaster
Objavljeno 06 april 2009 - 10:55
LP,
T
#21 ixi
  • 3.882 prispevkov
Objavljeno 08 april 2009 - 06:21
QUOTE (Blaster @ 6. Apr 2009 10:55:01) <{POST_SNAPBACK}>
LP,
T
#22 NLP
Objavljeno 08 april 2009 - 08:42
... če je to res kar ixi govori, se bodo hoteli vsi starih adamov rešit in jih menjat za novo serijo... poceni stari adamčki prihajajo whistling.gif
#23 Blaster
Objavljeno 08 april 2009 - 09:43
NLP, a je kdo od lastnikov S3A do sedaj jamral, da so naporni, nasikani, srednji in nizki nepoštelani in da so moteči?
Zvočniki so tako, kot mikrofoni, instrumenti... klasika, ki v primerjavi z digitalnim svetom ne zastara.
LP,
T
#24 NLP
Objavljeno 08 april 2009 - 11:32
Ne, ne sem prepričan, da so stari adami odlični, ampak novi so morda še boljši:)
#25 NLP
Objavljeno 08 april 2009 - 12:44
... evo kaj je rekel Klaus Heinz adamov dizajner:
"After 4 days at the Frankfurt show I feel entitled to say: the comments where as clear as they could be that the SX models are a big step forward, including Michael Wagner saying: "The S3A sound broken" - certainly not the case, but of course I was glad to have a positive comment from this so proven S3A user."
... kdo je Michael Wagener?
#26 Blaster
Objavljeno 08 april 2009 - 01:10
Ma na sejmu ne slišiš nič! Verjemi!
Samo da niso šli v ala K+H O300 sound... Zvočnike ful hvalijo, meni so pa totalen šrot. Vsaj v mojem placu.
#27 NLP
Objavljeno 08 april 2009 - 01:17
vem, vem, evo kaj je rekel George Necola (moderator na GS-ju in producent):
"Ive heard em at the MEsse together with Michael Wagener.
A/B old and new speakers.
they sound different.. a lot.
in my opinion more lowend, and more sizzzll..
youknow it was the Messe Frankfurt prolightsound.. a lot of noise.. an acoustic-guitarsong..
I liked the old one's better.. I need them A/B in my studio."
... res, vse je relativno, tak kot so se na primer meni focalke zelo dobro slišale...
#28 Blaster
Objavljeno 08 april 2009 - 02:18
QUOTE (NLP @ 8. Apr 2009 14:17:13) <{POST_SNAPBACK}>
Ker jih še nisi primerjal s studijskimi zvočniki. smile.gif LOL
#29 NLP
Objavljeno 08 april 2009 - 03:57
res ni bilo A/ B opcije.
Vseeno mislim, da so zelo dobri zvočniki.
Pa saj jih uporablja danes že zelo mnogo znanih inženirjev za svetovno uspešne albume.
Vsaka ušesa/ možgani imajo svojega tonca:)
#30 ixi
  • 3.882 prispevkov
Objavljeno 09 april 2009 - 06:27
QUOTE (Blaster @ 8. Apr 2009 13:10:29) <{POST_SNAPBACK}>
+1 se strinjam popolnoma.
sem jih poslušal v Thomannu preden sem šle na sejem, katastrofa Adam A7 so profesorji za te začetnike smile.gif
