Rusty Trombone in Shuriken Erectifier FREE plugin
6 odgovorov v tej temi
Objavljeno 19 marec 2009 - 12:37
Rusty Trombon in shuriken.se vam čisto zastonj ponujata svoj Erectifier plugin, domač na Windows in OSX platformi.
Kaj pa ta stvar sploh dela?
Preberite si:
Intro
A little while ago, we, Rusty Trombone of very little fame discussed how to get our music better (specifically the singing) and also how to get more ppl to notice us. So we commissioned this little VST from world famous VST developer www.shuriken.se, to give away for free, as marketing. Yeah, baby, for free, as marketing. Hopefully this will be as awesome for us as it is for you. Let us warn you though, we seldom read manuals, and we've never written anything like this. Anyways if you could listen a little to our music, tip a few friends of our music, be our friend at myspace, that would be awesome. please, we are begging, our knees are bleeding. puhlease.
What does what
So this works as a doubler, or demented phaser, it is designed to widen and phatten. Of course you can misuse that as well. you have an LFO that controls how long back an echo is. You can set the length and speed of this LFO. Then there is a filter that can be LowPass, HighPass or Allpass, and a cut Hz so that you can control where the cut is. oh-yeah!. The distortion is to gritt up the sound a little, or a lot, it's not the worlds bestest distortion. Then you can amplify the signal, if you want to. The filter can cut away a lot of the volume, that's why we have it. Then finally there is a on/off. There are two to the left side and two on the right side. and finally one dry through parameter. So if you'd like to test one of your settings, turn the other three off (via on/off parameter) and then tweak away, baby. There are a few presets (yeah, we didn't feel like making a lot of them, so we forced that shuriken.se guy to make a random-function and make a lot of presets there).
License
Ok, so this is free, you can use it on your tracks. It would be cool if you told us about it though. And it would be even cooler if you spread the word of Rusty Trombone. We don't take any responsibility for anything that this software might cause (unless it's good). Blah, blah, blah blah. Blbah blah blah. Oh yeah, if you want to put this plugin on a magazine coverdisc or something like that, it would be cool if you sent us an email and told us about it. A copy of the mag would be awesome.
Več info na: rustytrombone.se/blog
Še več FREE efektov pa lahko tudi najdete na spletni strani www.shuriken.se, programer je delal tudi za Betabugs...
Njegov moto: "Shuriken, sonic weapons for the music ninja":)
Uživajte in poročajte!
#2 saso
Objavljeno 19 marec 2009 - 01:09
NLP: In kje najdeš vse te plugine, ki jih daješ v novice? Predvidevam, da nanje ne naletiš čisto po naklučlju, ampak da imaš na zalogi kakšne dobre linke 'audio-novičarskih' strani...
Objavljeno 19 marec 2009 - 01:54
... iščem, raziskujem, mučim se... samo za vas!:)
Je kar ogromno virov:
kvraudio, harmony central, sonic state, gearslutz, gearwire, gearjunkies, prosoundnews, pa mnogo audio revij online, pa tudi naročiš se lahko na novice direktno...
... pa tudi sam večkrat na kaj naletim seveda.
Obesim gor kar se mi zdi zanimivo, pozivam pa tudi ostale, če jim je kaj interesantno in jaz izpustim, da se malo potrudite in kaj objavite!
Pa ne samo dat linka, brez slikic, nekaj mesa mora bit!
Večkrat tudi sam malo raziščem dalje, če je novica preskopa.
#4 minimalB
Objavljeno 19 marec 2009 - 08:36
Na kvraudio-u je prav sekcija, ki je namenjena samo zastonjcnikom in cisto vse kar se zgodi v zvezi s tem ti javijo iz prve roke. Jaz sem narocen na to ze kar nekaj let. Lahko pa tudi RSS uporabljas...
#5 Vale
Objavljeno 23 marec 2009 - 03:46
eden lepših plugov kar sem jih videl zadnje čase...
#6 ixi
Objavljeno 23 marec 2009 - 04:16
Če dela tut tko dobr k je lep je to SUPER!
#7 Vale
Objavljeno 23 marec 2009 - 04:29
QUOTE (ixi @ 23. Mar 2009 18:16:54) <{POST_SNAPBACK}>
off: kdaj prideš na per? biggrin.gif
