Vrhunske slušalke ATH-M50x v BT obliki
  • 3 819 prispevkov
Objavljeno 07 november 2018 - 07:44
Pri AT so nam ponudili vrhunske slušalke ATH-M50x v BT obliki. Brezžične slušalke se polnijo preko Usb-ja in napolnjene so zmože predvajati glasbo tudi 40 ur. Napovedan cena je 199 eur
Nekaj teh. specifikacij :
Type Closed-back dynamic
Driver Diameter 45 mm
Magnet Rare earth
Voice Coil CCAW (Copper-clad aluminum wire)
Frequency Response 15 – 28,000 Hz
Sensitivity 99 dB
Impedance 38 ohms
Battery DC3.7 V lithium polymer rechargeable battery
Battery Life Approx. 40 hours continuous use Charging Time Approx. 7 hours (for 0-100% charge)
Weight 310 g without cable and connector
Cable Detachable 1.2 m iS controller cable with mic
Connector 3.5 mm (1/8″) stereo mini-plug
Accessories Included 30 cm (1.0′) USB charging cable, protective pouch
Type (Microphone) Condenser
Sensitivity (Microphone) -42 dB (1V/Pa at 1 kHz)
Frequency Response (Microphone) 80 – 10,000 Hz
Polar Pattern (Microphone) Omnidirectional
Input Jack Micro USB Type B
Communication System Bluetooth Version 5.0
Output Bluetooth Specification Power Class 2
Maximum Communication Range Line of sight – approx. 10 m (33′)
Compatible Bluetooth Profiles A2DP, AVRCP, HFP, HSP
Support Codec aptX, AAC, SBC
Več info na : https://eu.audio-tec....com/m50xbt/en/
