Warm Audio napoveduje novo cenovno ugodno verzijo Classic Pultec EQP-1A
Objavljeno 09 januar 2015 - 06:23
Predkratkim so nam postregli že z eno klasiko in sicer FET 1176 Kompresorjem.
Sedaj napovedujejo legendarni EQ ..  Classic Pultec EQP-1A
Ne da so le na izgled naredili zelo podobno napravo, naj bi tudi dosegala zvokovno identičnost.
Cena naj bi bila £649,  dabavo pa bodo začeli vršiti v februarju 2015
Nekaj tehničnih specifikacij:
  • Tube Equalizer based on the classic “Pultec” EQP-1A
  • CineMag input and output transformers - Made in U.S.A.
  • Premium high voltage 12AX7 and 12AU7 tubes
  • CineMag inductor EQ section
  • EQ section can be bypassed - signal still passes through tubes and transformers for warming effect
  • No insertion loss - loss restored by tube amplifier
  • XLR and TRS transformer balanced inputs and Outputs
  • Flat frequency response from 20 Hz - 50 kHz
  • Boost and Cut controls can be used simultaneously for phase effect
  • Low frequency boost - 20, 30, 60, 100, 200, 400, 800 Hz - 12 db
  • Low frequency cut - 20, 30, 60, 100, 200, 400, 800 Hz - 18 db
  • High frequency boost - 3, 4, 5, 8, 10, 12, 16 kHz - 18 db
  • High frequency cut - 3, 4, 5, 10, 20 kHz - 14 db
  • 5 added frequency points for greater flexibility
  • Internal Switchable 115/230 Volt IEC Power Connection
#2 Psyko
Objavljeno 10 januar 2015 - 12:50
Odlično! Še malo pa bo hardware cenejši od pluginov :D
  • ixi in Ploki članom je to všeč
