Burl audio: Orca, Vancouver in BCLK
, dec 17 2012 08:50
Objavljeno 17 december 2012 - 08:50
B26 Orca
CONTROL ROOM MONITOR
The ORCA is the most highly evolved of all aquatic species. One who uses sonic superiority and harmony to dominate his environment, the ORCA is the APEX PREDATOR of all of the oceans of the Earth.
Thriving off of the Island of VANCOUVER, pods of ORCAS silently stalk their prey, present just under the surface; listening, threatening. The ORCAS’ superior sonic 3D imaging gives them an unfair competitive advantage over whatever they may view as prey. Surfers fear great white sharks. Great white sharks fear ORCAS.
Building on its reputation of sonic superiority, BURL AUDIO introduces the ultimate in control room monitoring, the B26 ORCA. The B26 ORCA utilizes the same analog, discrete circuit path philosophy as prior BURL AUDIO products with the emphasis on the ultimate in sonic transparency and 3D stereo imaging.
Evolve your listening, mixing and mastering through the B26 ORCA and give you and your ears an unfair competitive advantage.
Features:
• Direct coupled, discrete, class-A signal path
• 3 stereo mix inputs, 2 stereo tape return inputs, RCA stereo input
• 2 stereo speaker outputs
• Audiophile 0.1% matched resistor, stepped attenuator for control room level
• Independent studio/phones send and level
• External meter output
• Control room and Studio headphone outputs
B32 Vancouver
32 x 2 MIX BUS
VANCOUVER Island in Canada’s British Columbia is a lush, fertile land
of epic proportions. Teaming with wildlife and forests, life thrives in a
temperate climate drenched with the precipitation of the North Pacific.
The city of VANCOUVER on British Colombia’s mainland is a booming metropolis at the base of the Cascade Coastal Range. Known for its mindaltering substances, VANCOUVER is a hot bed for creativity. In addition to the BX5, the B32 VANCOUVER introduces a new concept to the summing amplifier, GAIN BOOST. Adding gain boost with the BX5 will give your mixes that glue that you have been seeking ever since retiring your 2-track analog recorder. With 32 input channels and switchable tonality, the B32 VANCOUVER will allow your mixes to thrive in depth, warmth and clarity. Use the B32 VANCOUVER in conjunction with the B1 MIC PREs, the B80 MOTHERSHIP and the B26 ORCA and you will achieve THE COMPLETE SOLUTION.
BURL AUDIO introduces its latest hot bed of creativity, the B32 VANCOUVER, a 32 channel mix bus. Based on BURL AUDIO’s renowned discrete analog, class-A circuitry, the B32 mix bus employs both the transparency of the B26 ORCA, plus the switchable tonality of the new BURL AUDIO BX5 output transformer.
Features:
• Discrete, class-A signal path
• 8 mono inputs, 24 stereo inputs
• Audiophile 0.1% stepped attenuators
• Switchable BX5 output transformer
• Summing amp GAIN BOOST
• Dual stereo outputs
BCLK is a word clock distribution card for the Burl Audio B80 Mothership featuring 9 Word Clock Outputs (8 BNC, 1 AES), two independently programmable banks, extremely stable, low jitter clock and up to 92 Word Clock outputs in 1 Mothership!
MSRP is $2499 for the B26 Orca; $2299 for the B32; $999 for the BCLK
Več info na:
http://www.burlaudio.com/
