Po deinštalaciji Cubase-a se mi pri zagonu windowsov( XP Pro 64 BIt ), konstantno pojavlja tole sporočilo Can't open AsIO.sys !! (2),mogoče kdo ve kako naj se ga znebim? Thanx!!
circuitbreaker
, nov 25 2008 09:06
Objavljeno 25 november 2008 - 10:08
Na spletu pravijo da se to pojavlja pri Asus hardveru, poskušaj naslednje:
This error is due to the aaCenter.exe loading at startup. You can get rid of the error by stopping it from starting. This runs as a scheduled task.
Start->Accessories->System Tools->Task Scheduler
On the right you'll see the Library, drill down into the Asus tasks and disable ASUS ACPI Service Provider task, and ASUS RegRun Loader task. This will kill the error from popping up, but leave the stuff on your computer if you wish to use it at a later time.
