Manley MicMAID 4x4 Mic/Micpre Matrix-Switcher
4 odgovorov v tej temi
  • 5 981 prispevkov
Objavljeno 19 junij 2011 - 08:54
Any mic, any pre, any time. Plug your four favorite mics and micpreamps into the MicMAID, and pick the best combination for every session. With its convenient level-matching capabilities and user-programmable routing schemes, this is the ultimate tool for auditioning and comparing your finest equipment. Get ready to find the sound you're looking for faster (and easier) than ever. Start cleaning up YOUR workflow with a MicMAID. The MicMAID was designed to fill a particular niche in the business that has never really been addressed: auditioning and selecting microphones and microphone preamplifiers. Proper pairing of mics and preamps has always been (and always will be!) a vital step in the tracking process, but there has never been a simple, accurate way of doing this. Since we are in the business of providing tools to professional sound engineers, we saw this obstacle as an opportunity to flex our design muscles and create something that could finally fill this void.
In the past, records were made in studios. Big studios, with big consoles, with banks and banks of microphone preamplifiers. With a console full of micpre's available, it was easy to audition several microphones through four almost identical preamps. In today's world, however, most do not have this luxury. In a home studio, most people only own a few preamps and a few microphones. With a conventional patchbay, auditioning gear takes time - muting monitors, unplugging sources, repatching, adjusting gain for the new microphone or preamp - and in this time, our memory for the sound we just had a minute ago (or more) has faded. We might recall a general idea ("breathy", "boomy", etc.) but we don't REALLY remember precisely what we were hearing.
With the MicMAID, this problem is solved. Four mics are plugged in, four preamplifiers are plugged in, and that's it. Hear any mic through any pre, any way you like. For each of the four signal paths, levels are easily adjusted and saved - this level-matching fixes the all-too-common problem we encounter when we just assume the "louder" signal path is the "better" signal path. Subtle sonic differences between pieces of equipment are now instantly percievable, with a simplicity never previously available.
In addition to the four main outputs the routing matrix provides, there is a fifth output labeled MON/REC on the rear panel. Although this is described as a "monitor" output, this output can (and should) be used for recording purposes - for it is only this output that utilises the active components of the MicMAID. These include the level-matching capabilities and the Variable Phase section of the unit. When the continuously variable phase circuit is selected, it allows you to easily phase-align the selected mic signal (or the front-panel DI signal) with another microphone. This phase adjustment has an all-pass filter with two selectable center frequencies, making it useful on a variety of sources.
With four passive hard-wired signal paths and its versatile monitoring section, we'd like to think that the MicMAID can help you find the sound you're looking for just a little quicker than you could before. It's a tool of the trade, and as with all tools, you should feel free to be creative and think up new ways to use it that make your life easier and your recordings better.
Več info na: http://www.manley.com/mmaid.php
Cena: SRP $3,500
Pripete datoteke
#2 baadc0de
baadc0de
  • 320 prispevkov
Objavljeno 20 junij 2011 - 02:41
A se samo meni zdi bedno/cudno da se omenja v marketing blurbu home studije, potem pa se da ceno 3500$ na signal router? Ali se samo meni zdi veliko.. Ne dvomim v kvaliteto, samo storija s home studijem mi ne drzi vode.
Prispevek uredil/a: baadc0de, 20 junij 2011 - 02:41 .
  • 5 981 prispevkov
Objavljeno 20 junij 2011 - 11:28
Hmmm kaj pa vem... to je zelo relativno kaj je 3.500$ glede na to, da so v SLO podpovprečne plače glede na sosednje razvitejše države (Avstrija, Italija...).
... in glede na to da so resne komponente "tu nekje in še 2X več"...
Potemtakem niti ni drago:)sad.gif
#4 baadc0de
baadc0de
  • 320 prispevkov
Objavljeno 21 junij 2011 - 06:12
QUOTE (NLP @ 21. Jun 2011 00:28:54) <{POST_SNAPBACK}>
Ok, samo se pogovarjamo o tem da placas 3.500$ za to da ne pretaknes 1 XLR na takem patchbayu ampak raje pritisnes en knof. Mogoce je samo moja hiba da ne tretiram studijev ki imajo 7.000$ ali vec vredne posamezne komponente kot home studije, ker je sestevek kar malce predrag da bi bil domac hobi.
  • 5 981 prispevkov
Objavljeno 21 junij 2011 - 06:41
hja samo tukaj gor piše Manley:)
