Logic Pro 9
233 odgovorov v tej temi
#1 Musician
Musician
  • 4 prispevkov
Objavljeno 23 julij 2009 - 06:50
Logic Studio
New in Logic Studio:
Flex Time is a new collection of features that lets you manipulate timing and tempo quickly and creatively. Experience editing without all the cutting.
Flex Tool
The new Flex Tool lets you push audio around with your mouse by clicking and dragging anywhere on the waveform — forget all that tedious splicing and editing.
Audio Quantize
It's not just for MIDI anymore. Now you can conform the timing of an audio region to a musical grid, or to the feel of another track, instantly correcting a performance.
Editing drum tracks
Use Slicing Mode with drums and you won't compromise a single attack. Edit across a set of grouped multitrack drums and everything stays locked perfectly in phase.
Varispeed
Slow down or speed up an entire multitrack project effortlessly, whether you want to try out different tempos or take it slow while you play a difficult solo.
Flex Modes
Whether you're editing a solo vocal, a rhythm guitar, or multitrack drums, Flex Time has a mode designed to give you the best results.
Speed Fades
Get creative by adding turntable-style starts or stops with the kind of precision that would impress even the best DJs.
Tempo Import/Export
Now the audio you import can automatically conform to the tempo of a project you're working on. (And the other way around.)
New production tools allow musicians to tackle any part of the recording, editing, and mixing process they want — and get it done in a fraction of the time.
Selective Track Import
To transfer setups and track content between projects, simply select the individual components you want to import on a track-by-track basis.
Expanded take folder editing
Logic Pro 9 gives you access to your important edit tools and Flex Time features — right alongside Quick Swipe comping.
Drum Replacer
Now you can replace or double less-than-perfect drum tracks with triggered samples in just a few clicks. No more headaches. No more hassles.
Convert to Sampler Track
In one step, turn an audio region into a sampler instrument with a MIDI track to trigger it. Then you can modify and resequence the part.
Bounce-in-Place
The new Bounce-in-Place feature makes effects rendering much quicker and easier, whether you're bouncing a single region or an entire track.
Notation and chord grids
Create guitar tablature or detailed scores using a library of more than 4000 chord grids (or your own custom grids) and new ornaments for hammer-ons, bends, and more.
Jam Pack: Voices
Build your song with a lead vocal, rappers, backup singers, an entire choir, or even software instruments based on the human voice and body.
Warped Effects for Space Designer
More than 450 warped impulse responses radically transform what Space Designer can do, allowing you to give ordinary sounds a bizarre, other-worldly quality.
Now you can mix and match amp heads, EQs, reverbs, speaker cabinets and mics—then creatively route your signal through an impressive new collection of stompboxes.
Amp Designer
Build your dream rig by mixing and matching 25 amps, 25 speaker cabinets, and 3 mics you can position freely around the speaker cone. Hear it now
Pedalboard
Fire up 30 stompboxes that deliver lush effects like Overdrive, Distortion, Fuzz, Delay, Chorus, Flanger, Phaser, Tremolo, Treble Boost, and Wah. Hear it now
Classic tones
Hundreds of presets give you Amp Designer and Pedalboard sounds that are ready to go. Start exploring with classic tones, genres, or characteristics like clean, crunch, and distorted.
Apogee GiO support
This new USB audio interface and control device lets you operate Pedalboard hands-free and works with Logic Pro 9 and MainStage 2 right out of the box.
MainStage 2 lets you hit the stage with all the same instruments and effects you used on your recording, and adds a backing track player and live loop recorder.
Playback
With this new plug-in, your Mac becomes a flexible, reliable backing track player. Fill out your sound with a simple stereo track or a set of separate, mixable stems.
Loopback
This live loop recorder lets you create spontaneous arrangements onstage. And it's instantly familiar, since it's modeled after the tape-based devices you know and love.
Multimapping of controls
Set things up so that one knob controls multiple plug-in parameters. Then you can dramatically change your sound with the turn of a single knob.
Grouped controls
Drag and drop entire sets of knobs, dials, faders, meters, and more into your layout. From there, you can easily customize the type, size, and color.
Full ReWire support
Run MainStage with applications like Reason and Live. Trigger and sequence your instruments from MainStage, and route your signals straight into the mixer.
Record performances
Route your audio to a designated stereo output and choose from all the standard file formats, including Apple CAF for concerts of almost any length.
Explore artists' projects.
Explore Logic Studio files created by the Killers, Lily Allen, and Santigold.
Price:$499
Prispevek uredil/a: Musician, 23 julij 2009 - 06:52 .
#2 Blaster
Objavljeno 23 julij 2009 - 08:02
Super... žal še vedno ne premorejo region volume edita in direct monitoringa (za to je pač kriv CoreAudio...)
#3 jetam
Objavljeno 24 julij 2009 - 11:31
To dela tudi na starejših MAC-ih (G5...)?
#4 exorciser
exorciser
  • 108 prispevkov
  • Interests:Mjuzik
Objavljeno 25 julij 2009 - 01:10
bojda ne, nekaj priloženih programov ne dela na tigru, je treba leoparda že met
Prispevek uredil/a: exorciser, 25 julij 2009 - 01:16 .
#5 minimalB
Objavljeno 25 julij 2009 - 10:02
Koncno so tudi malo audio del izboljsali... par stvari je prav elegantnih!
Ampak kot pravi Blaster... dokler ne porihtajo v samem osx sistemu direct monitoring je za marsikoga delo na osx s katerimkoli audio programom omejeno in motece...
To je definitivno eden od razlogov, zakaj je veliko ljudi se vedno na windowsih...
#6 Blaster
Objavljeno 01 avgust 2009 - 01:06
Pravkar sem naložil Logic Pro 9 in v njem našel kar nekaj novih uporabnih zadev. Med njimi Flex Time (zadeva res dela...) ter Speed "fade-ing". Zakon... Upam, da isto naredijo tudi v Nuendu 5. smile.gif
Drugače še vedno precej nepregleden in okoren za uporabo, če si Steinberg user. biggrin.gif
#7 filipich
filipich
  • 125 prispevkov
Objavljeno 13 avgust 2009 - 02:48
Zdravo,
malo sem bom spustil v logic in me zanima, kaj predlagate (oziroma kašna je razlika): Logic Pro ali Logic studio?
hvala, lp
#8 turban99
turban99
    Tim Urbanya
  • 235 prispevkov
Objavljeno 13 avgust 2009 - 04:30
QUOTE (filipich @ 13. Aug 2009 15:48:12) <{POST_SNAPBACK}>
Zdravo,
hvala, lp
Logic Pro in Logic Studio enaka aplikacija!:) Oz. včasih je bil Logic Pro.. do verzije 7.. od takrat naprej je pa Logic Studio!
Če te pa zanima stara verzija Logic Pro 7 pa povej, ti ga prodam!:)))
#9 filipich
filipich
  • 125 prispevkov
Objavljeno 13 avgust 2009 - 07:20
#10 Blaster
Objavljeno 13 avgust 2009 - 10:32
Logic Pro JE in JE BILA aplikacija... Logic Studio pa je programski paket, ki vsebuje poleg Logica Pro še Waveburner, Mainstage in še par aplikacij.
#11 turban99
turban99
    Tim Urbanya
  • 235 prispevkov
Objavljeno 14 avgust 2009 - 11:06
QUOTE (Blaster @ 13. Aug 2009 23:32:30) <{POST_SNAPBACK}>
Tako je! smile.gif Malo površno sem napisal...
#12 Ploki
Objavljeno 26 september 2009 - 09:39
QUOTE (Blaster @ 23. Jul 2009 21:02:35) <{POST_SNAPBACK}>
ja ga. v Inspectorju je, pod "Region parameters"
http://documentation.....r=3&section=6
#13 Vale
Objavljeno 26 september 2009 - 04:24
This update improves overall stability, provides numerous fixes and enhancements, and is recommended for all users of Logic Pro 9.
Some issues addressed include (but are not limited to):
* Replace mode now functions as expected when Punch Recording.
* Trimming a region now behaves correctly for regions whose first transient is quantized.
* Using "Paste at Original Position" in the Arrange window now works as expected.
* Using track import Replace to channel strip used on multiple tracks in the Arrange window now works as expected.
* Correct automation values are now maintained when one region is moved over another with the "Move Automation with Regions" option.
* Addresses an issue where the Save button on a Logic/Mackie Control stays lit when pressed with some projects.
* The Reassign Track shortcut menu now correctly displays the currently assigned channel strip object.
* Text Only mode for the Toolbar now remains in effect when an option is clicked on the Toolbar.
* MIDI commands can now be assigned to key commands with fixed assignments.
* Clicking solo on a channel strip no longer selects the channel strip.
* Fixes an issue where Logic would quit unexpectedly if the grid value in the Hyper Edit Convert Event definition dialog was changed.
* MIDI regions now play at the correct tempo when scrubbed with the Solo tool.
* Current project Mixer settings are now correctly maintained when importing tracks with "Send all fader values" enabled.
* EXS24 now correctly displays all parameters in Editor view for instruments created in Logic 8.
* Logic no longer quits unexpectedly in recording situations where both a MIDI and audio track are record enabled and the MIDI track is not selected.
Enhancements implemented include:
* It is now possible to measure and provide latency compensation for an external signal chain that is routed via the I/O plug-in.
* You can now snap align Flex Markers to MIDI notes within other tracks in the Arrange window.
* The Automap feature for Novation MIDI controllers now functions when using the Logic Studio plug-ins.
* Apogee's UV-22 dithering algorithm now an option when bouncing audio files.
#14 Gregor Zemljic
Gregor Zemljic
  • 210 prispevkov
Objavljeno 26 september 2009 - 06:49
#15 Blaster
Objavljeno 26 september 2009 - 06:58
#16 Vale
Objavljeno 26 september 2009 - 10:17
#17 beatmakerr
Objavljeno 26 september 2009 - 10:25
QUOTE (Vale @ 26. Sep 2009 23:17:39) <{POST_SNAPBACK}>
Lepa biggrin.gif hehe
#18 Vale
Objavljeno 26 september 2009 - 11:37
#19 Blaster
Objavljeno 27 september 2009 - 01:34
Ma sej logic je ql stvar, sam ko pridem do audio editinga, najprej pomislm na tablete za živce. tongue.gif
#20 Gregor Zemljic
Gregor Zemljic
  • 210 prispevkov
Objavljeno 27 september 2009 - 09:47
Jaz sem bil na Cubase od 1.0 verzije na Atariju naprej......na Macu do Cubase Audio 5.1, kupil ProoToolse (4,1 TDM), zelo hitro prodal ker so bili meni neuporabni za produciranje , se pa
strinjam da je bil audio editing takrat najboljši.....ko je prišel ven Cubase SX, počakal do verzije 2....videl da je ta še slabša od enke..... violent085.gif
Ravno takrat je Apple kupil Emagic....dal ven Logic Pro 6......kupil in nikoli pogledal nazaj.....par frendov je potem tudi zamenjalo religijo in smo vsi zelo predani verniki in smo hvaležni za vse darove , ki jih dobimo (plačamo).....
Občasno še vedno delam v kakšnem studiju na Nuendu ali Pro Toolsih.....super za snemanje....za resno moderno produkcijo.....pa potrebuješ orodja , ki so na razpolago v
Logicu.....nobenih 3rd party plugsov ne rabiš, sam po sebi je samostojen software z vrhunskim zvokom in kar je zame najbolj bistveno, orodje za komponiranje in produkcijo
glasbe.....z zelo dobrimi snemalnimi in editing možnostmi....samo malo časa si je treba vzeti da zaštekaš logiko.....če ti to ne zadostuje je problem v tebi ali si pa kupiš Toolse....kjer
pa ni precej stvari, ki so v Logicu samoumevne.....
Meni je vedno delal super.....za moj način dela je idealen...zdaj ko imam enostaven način latency kompenzacije na i/o plug in je pa zmaga......
V9ki so mi super amp simulatorji, fade, region gain, novi multiple tool option, dodaten euphonix support, + par malih detajlov....ostalo je pa več ali manj isto kot v 8ki........flex pa
še nisem imel prilike sporobat.....pa še par drugih dodatkov tudi ne..... ashamed0002.gif
G
#21 Blaster
Objavljeno 27 september 2009 - 10:44
Primarno uporabljam Nuendo 4.3, ki mi je enostavno fantastičen... Logic uporabljam občasno in je v primerjavi z nuendom ful bolj okoren za delo, v nuendu sem 3x hitrejši, že za razne fade-in, fade-out, region volume, itd ... si morš vzet čas, pri Nuendu je to stvar enega klika.
Drugače je za komponirat pa tko, res super orodje ... audio je pa rahlo zmeden. Še stereo špure ne zna prikazat v "stereo wave-u". tongue.gif
LOL
#22 Psyko
Objavljeno 28 september 2009 - 01:16
Mah ... vsak ma svoje prednosti in slabosti. Ktera logika ti najbolj paše, s tistim pač delaš .
Nevem, Nuendo še vedno nima pametnega mixerja, ki bi hkrati lahko prikazal inserte in sende. Na srečo so končno side-chain porihtali ..pa editing audia je res super fast.
Logic, se mi zdi na čase zlo neodziven. Stisneš record .. čakaš.. stisneš stop.. čakaš. smile.gif Je pa super za produkcijo (environment rules:P)
Mene je letos še vedno najbolj navdušil Studio One. Glede na to da je v1.0 dela res prekrasno. Hiter, odziven, audio leti, midi dela. Mixer super... razn čudnega steinberg poimenovanja aux-ov (Fx channel ?! smile.gif
Od danes naprej pa si lastim cubase 5 .. bomo vidli kaj bo ta rekel smile.gif
#23 Gregor Zemljic
Gregor Zemljic
  • 210 prispevkov
Objavljeno 28 september 2009 - 07:59
QUOTE (Blaster @ 27. Sep 2009 23:44:22) <{POST_SNAPBACK}>
Zgornja polovica je levi kanal, spodnja pa desni.....na stereo tracku.....meni se zdi to super rešitev....precej manj prostora vzame.....
QUOTE (Psyko @ 28. Sep 2009 02:16:36) <{POST_SNAPBACK}>
Stisneš record .. čakaš.. stisneš stop.. čakaš. smile.gif Je pa super za produkcijo (environment rules)
Si vklopil Punch in recording?
LP G
#24 Psyko
Objavljeno 28 september 2009 - 08:47
QUOTE (Gregor Zemljic @ 28. Sep 2009 08:59:52) <{POST_SNAPBACK}>
LP G
sej lih to me mal zmoti pri Logic-u, na sveži inštalaciji porabiš vsaj 15 minut da si nastaviš tekoč workflow.
Je pa res da sem ga vedno testiral na navadnem Macbook-u, kjer je kr hitro postal chubby (že po +20 pluginih)
Nevem, mogoče sem se pa preveč razvadil na Steinbergovih produktih. Tam lahko imaš več kot 80 trackov polnih pluginov, pa bo še vedno rock solid v odzivnosti.
LP M
Prispevek uredil/a: Psyko, 28 september 2009 - 08:51 .
#25 dorko z motorko
dorko z motorko
  • 42 prispevkov
Objavljeno 28 september 2009 - 10:11
Meni fajn dela, sicer mam čist novega Maca, a vseeno...
To je vse R´N´R !
#26 matejd7
matejd7
  • 122 prispevkov
Objavljeno 28 september 2009 - 11:39
V 9ki je pod Global - Editig funkcija Fade Tool Click Zones in pa Marquee Tool Click Zones tako da za fade in pa marquee ni več potrebno prestavljati na drug tool, pa še rezanje je zdaj super fast, označiš z marquee in klik v zgornjo polovico waveforma in je to to. Še region volume porihtajo na sami regijah pa bomo počasi tam. strongbench.gif
Prispevek uredil/a: matejd7, 28 september 2009 - 11:45 .
#27 Blaster
Objavljeno 28 september 2009 - 12:14
QUOTE (matejd7 @ 28. Sep 2009 12:39:42) <{POST_SNAPBACK}>
... ni več potrebno prestavljati na drug tool, pa še rezanje je zdaj super fast, označiš z marquee in klik v zgornjo polovico waveforma in je to to. Še region volume porihtajo na sami regijah pa bomo počasi tam. strongbench.gif
#28 exorciser
exorciser
  • 108 prispevkov
  • Interests:Mjuzik
Objavljeno 29 september 2009 - 11:32
Hej,
Ali se da note (kvadratke) v Piano Rollu premikat kako drugače kot z miško?
#29 exorciser
exorciser
  • 108 prispevkov
  • Interests:Mjuzik
Objavljeno 07 oktober 2009 - 09:20
QUOTE (exorciser @ 30. Sep 2009 00:32:53) <{POST_SNAPBACK}>
Hej,
simpl
#30 turban99
turban99
    Tim Urbanya
  • 235 prispevkov
Objavljeno 13 oktober 2009 - 11:46
Update 9.0.2. je zunaj!:))) woo hoo... gremo update-at pa da vidimo če so kaj popravili!:)
