Logic Pro 9
#152
Objavljeno 13 april 2010 - 09:54
LOL
http://www.drogart.org/forum/
nujna vzdrževalna dela
#154
Objavljeno 13 april 2010 - 11:20
#156
Objavljeno 14 april 2010 - 07:06
#159
Objavljeno 14 april 2010 - 11:02
#160
Objavljeno 14 april 2010 - 11:14
naj tako povem:
artist/producer še ni dober engineer...> pa tudi engineer dostikrat še ni dober tehnik... > ki ve kaj naj bil DAW Audio engine počel.
sodeč po tistem postu mu pa ni jasen 1.) Pan law 2.) koncept digital audia
kar ne pomeni da je slab artist/producent ali celo engineer.. pomeni samo da je prelen da bi si prebral koncept digital audia.
phh.. se glossary:
artist/producer: nekdo ki se ukvarja z glasbo
engineer: nekdo ki to glasbo miksa
tehnik: nekdo ki mu je jasno kako deluje kompressor(ne kaj delajo gumbi, kako v resnici deluje) in summing engine in nevem kaj se vse
idealno si mocan nekje ali pa na dveh podrocjih o tretjem se ti pa vsaj malo sanja. eni so pac mocni samo na enem
Prispevek uredil/a: Ploki, 14 april 2010 - 11:18 .
#161
Objavljeno 14 april 2010 - 11:20
What is your studio like? Hardware, software, or a mixture?
I’ve operated in a fully digital studio for quite a while. The heart of the studio is my Apple computer. I use a Mytek sound card and converter, and I just got Pro Tools HD1. I used to work with Pro Tools, but I shifted to Logic some years ago. Logic 9 is a very good program and I’ll continue to develop my tracks in it, but as I found the sound and engine of Pro Tools a bit better, I’ll transfer the files and do the final mix in Pro Tools in the future. I use Quested HM 412 speakers, which are real monsters and produce great sound, and additional Yamaha NS10 speakers for controlling.
http://www.beatporta...ing-to-dynamic/
#162
Objavljeno 14 april 2010 - 12:12
phh.. se glossary:
če je samo fora nastavitev v logicu te razumem, da mogoče strelja v prazno ker nima pan law naštimano kot mora. če predpostavljamo da je vse naštimano kot mora, si mu bom upal prisluhniti . zdaj pa lahko razvijemo še eno mac vs PC alike temo zarad mene
#163
Objavljeno 14 april 2010 - 01:25
nimam Logica 8 tle, drugače je rešitev tako preprosta da brezveze, ker je logic 9 in 8 kompatibilen med sabo
1.) narediš projekt z naključnimi panoramami
- projekt ne sme vsebovati kakršnih koli random LFOjev ali random reverbov (2c audio, lexi), vsi kar je random more bit printano
vse tracke nastaviš z gaini tako da so faderji na uniti gain, ker ima logic9 drugačno resolucijo faderjev.
2.)
- odpreš v lp9, bouncaš
- odpreš v lp8, bouncaš
odpreš bilokje, obrneš fazo... in to je to.
jaz trenutno nimam logica 8 .. bom skinil ko bom imel čas. ampak mislim da so bučke..
Prispevek uredil/a: Ploki, 14 april 2010 - 01:26 .
#164
Objavljeno 21 april 2010 - 03:40
torej imel sem inštaliranih ene par syntov (crack)
vse igralo vse ok, ampak potem mi je ka naenkrat vrglo vse ven z logica? pomoje po update-u al kdaj?
sicer stvar je še inštalirana na sistemu, samo ne znam nazaj notr dat? al se ne da, pa morem ponovno inštalirat?
hvala, lp
#165
Objavljeno 22 april 2010 - 06:20
se da kako uštimati da bi "merge" deloval tako, da bi vključil tudi tišino do konca oz. začetka bara? prilagam slikovni primer, da se bo lažje videlo kaj mislim...
tukaj se lepo vidi kako pri "merganju" 4 kickov ostane še nekaj prostora do konca bara, jaz bi pa rad imel regijo skozi cel bar, da jo lahko potem preprosto loopam...
pri cubasu vem da se je dalo regijo preprosto raztegnit, v logicu pa to ne gre ali pa jaz neznam.
hvala in lp!
#168
Objavljeno 24 maj 2010 - 10:59
Mislim da ne! Rešitev je , create new track with duplicate settings!
Ti avtomatsko naštima nov track z ultrabeatom in istimi nastavitvami... potem pa naložiš še novih 8 mono trackov!
#171
Objavljeno 25 junij 2010 - 06:50
ampak, sem se podal na research in bojda je to feature
http://www.gearslutz...ltrabeat-3.html
post #70 pa dalje
pa lih nadr*u sm se tega klavstrofobicnega ritommashina in ze ga bo treba menjat :-[
Prispevek uredil/a: Katoda, 25 junij 2010 - 06:53 .
#172
Objavljeno 26 junij 2010 - 10:16
pa pol se naprej
dobr znak je da ni delay
to je verjetno cist precaution ce se ti sempl ne zacne na 0 pointu
#174
Objavljeno 12 julij 2010 - 01:37
im pissed
#178
Objavljeno 23 avgust 2010 - 09:10
sej ni 2x za rect, zaenkrat mam se nekaj tresholda tolerance, ko bo puklo, bomo samo se znanci
evo se en kvescon, ko zazenem logic in odprem projekt se zmeraj ama zmeraj najde nek track, ki pridobi na funkciji zasciten solo --->
zakaj je tako ? sem kaj prepustil ? tudi ko izklopim da se rdeci slash pobere se drug dan ko zalaufam isti zgodi. anojing
